IPPA login using alphanumeric characters
Jun 18th, 2008
I installed UCCE 7.0 with CAD services.
The agents are able to login but just using numbers. I need to let them use alphanumeric characters.
The created services on CCM points to:
http://<CAD services server>/ipphone/jsp/sciphonexml/IPAgentInitial.jsp
How can I do?
Overall Rating: 5 (2 ratings)
mmaddalena Wed, 06/18/2008 - 00:54
I forgot to say that the service is the IPPA service...
Aaron Harrison Wed, 06/18/2008 - 09:21
  • Community Spotlight Award,
    Member's Choice, May 2015
Search your server for a file named TIAJ.cfg.
Open this in notepad and look for lines similar to this:
inputflag.login.id=N
inputflag.login.pwd=N
If set to =N, it will look for Numeric input. If =A, it will be Alphanumeric.
Do this then you will need to restart the tomcat service.
Aaron
Please rate helpful posts...
