Gateway and PBX
Jun 18th, 2008
Dear all
I have ericsson MD110 with cisco voice gateway.the connectivity between cisco and MD is ok but its an issue.
MD has PRI from telco to call outside.
I defined a dial-peer with destination-pattern 9
I expected to hear telco when i call 9
but it seems the MD waits for more digit.
the other point is that I can not user 9T in my destination pattern.
paolo bevilacqua Wed, 06/18/2008 - 03:59
  • Hall of Fame,
    Founding Member
Hi, you cannot get dialtone from PRI. If your numbers are of variable length, you need to use T, there is no way around that.
