Troubleshooting configuration register issues
Jun 18th, 2008
Hello,I mistakenly change my 2620 router configuration register value to 0x1202.How can I set my pc hyperterminal to communicate with the router as it has not been able to communicate with it since then.I understand that such value has changed the default console speed to 1200.I have tried to change the baud rate on the PC to 1200 to no avail.
I will be glad if I could be helped to restore it to it default value
Overall Rating: 5 (2 ratings)
mahmoodmkl Wed, 06/18/2008 - 02:13
  • Gold, 750 points or more
U need to try one by one all the baud rate available on u r terminal in order to get access to the router n change the value to 0x2102.
Mahmood
Pravin Phadte Wed, 06/18/2008 - 02:53
  • Silver, 250 points or more
In hyperterminal go to the properties and configuer and change the baud rates and check.
Pravin
isammed000 Wed, 06/18/2008 - 08:22
HI Pravin,
Thank u for the message you sent to me.I have fixed up the problem.I tried to use all the baud rate one after the other and one of it works out.
Thanks alot for that clue
isammed000 Wed, 06/18/2008 - 08:27
Hi Mahmood,
Thanks for your message.I have fixed up the problem.I tried to use the baud rate one after the other as u suggested and one of it works out.
Thanks alot for the clue
