Jon Marshall Wed, 06/18/2008 - 02:22
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Feature Navigator is the tool you need to use. You can search by platform ie. 3660.
I had a look for you and you need to be running IP PLUS IPSEC 3DES as a minimum. This was with version 12.3(1). Without knowing how much memory you it's difficult to be more precise + you may need other features not available in that feature set.
As i say, check out Feature Navigator, it is very easy to use.
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
Jon
a.alekseev Wed, 06/18/2008 - 03:36
  • Gold, 750 points or more
k9 or k8 must be in IOS's name
for example
c3725-spservicesk9-mz.123-17.bin
