Catalyst 3560G Communications via HTML/Javascript
Jun 18th, 2008
Dear Sir,
I am attempting to create a HTML Web-page to make use of the 'Force-Authorized', 'Force-Unauthorized' and 'Auto' IOS-commands to enable/disable a prespecified 'Port' and 'Switch' within our Cisco Switch Network. This has been sucessful. However; the IOS-commands return a HTML page which verifies the sucess of the command which also contains the option to submit a further 'Command'. Is it possible to supress this page or atleast capture this page into a file? Is it also possible to check the status of a specific port using, say Javascript?
Yours sincerely,
John Toet
