Cisco 7204 vxr, NPE G1 , dual PSU's
Jun 18th, 2008
Does anyone know of a command that will allow me to check if 1 of the 2 PSU's is faulty? I have an ongoing fault at the moment where 1 PSU is plugged into Comms Cabinet 1 which is fine but the 2nd PSU is plugged into a comms cabinet where the power is suspect. The command show environment all just shows that power is restored but I am looking for legacy information on the PSU.
Mary
Pravin Phadte Wed, 06/18/2008 - 03:42
  • Silver, 250 points or more
try show environment all
Hope this helps,
Pravin
Giuseppe Larosa Wed, 06/18/2008 - 06:30
  • Hall of Fame,
    Founding Member
Hello Mary,
if you want to see what happened before you may check the logging buffer with sh log.
To verify if the PSU is working correctly you should connect it to a power source you know it is working fine.
the PSU should have some LEDs on them to signal if they are on (green) or faulty.
hope to help
Giuseppe
maryodriscoll Wed, 06/18/2008 - 06:34
Giuseppe
Nothing in log file and I am in a remote location so can't check PSU lights. I am surprised that there is no command to see if the PSU ever failed (nothing ever in logfile /environment log). Anyway, never mind, I give up!
mMary
