gre tunnel with dynamic IP
Jun 18th, 2008
Dear ,
I'm trying to create GRE tunnel between two Cisco 877 routers by using ddns
interface Tunnel1
ip address
tunnel source Dialer1
tunnel destination
The domain name under is resolving immediately to IP and when I do show run tunnel destination is showing me as IP address and this is making problem . Because remote end point for the tunnel is dynamic IP and it's changing everytime . I want to use tunnel destination as domain name and not as IP ? Is there is any way
michael.leblanc Wed, 06/18/2008 - 14:38
I would assume that the IP address is changing frequently because you are not keeping the tunnel up.
Perhaps you could keep the tunnel up using GRE Keepalives.
interface Tunnel0
keepalive 5 4
The only time you would likely see a change in IP, would be following a power outage.
Not the perfect solution you are seeking, but it could significantly improve your situation.
hennigan Wed, 06/18/2008 - 15:07
interface tunnel1
ip ddns update
ip address
tunnel destination
Also search Cisco docs for "ip ddns" show and debug commands, options.
