show post command
Jun 18th, 2008
Hi.
Is there a command like "show post" on a 2811 router like on a catalyst switch which indicates or shows the status of the "power on self test" after the router is working and finished its power up?
Thank you.
Overall Rating: 4 (1 ratings)
paolo bevilacqua Wed, 06/18/2008 - 05:09
  • Hall of Fame,
    Founding Member
ISR routers don't have POST. You can do "show diag" to see what is installed in the router.
