WAAS CIFS MSS
Jun 18th, 2008
There is an option to specifically define the CIFS mss within the WAAS command line. Is this option not inherited from the Global TCP settings? Why is there a separate parameter? Thanks.
Overall Rating: 5 (2 ratings)
dstolt Wed, 06/18/2008 - 06:02
  • Cisco Employee,
Michael,
It is specifically for the CIFS Application Optimization connections. All other connections use the TCP MSS settings. This setting will not be needed after WAAS 4.1.
Hope that helps,
Dan
robertsmichael Tue, 12/23/2008 - 16:38
Looking at the 4.1.1c code, I don't see a tcp mss command. Is this replaced by the mtu sub-interface command?
dstolt Tue, 12/23/2008 - 20:19
  • Cisco Employee,
You should be able to find the TCP MSS settings under the following area in the GUI:
Device/Configure/Acceleration/TCP Settings:
Hope that helps,
Dan
