Contact Center
Hi ,need some help on this error message.The error was: A built-in element encountered an exception of typecom.sun.jersey.api.client.ClientHandlerException. The root cause was: com.sun.jersey.api.client.ClientHandlerException: java.net.SocketTimeoutE...
kavle by Level 3
  • 128 Views
  • 4 replies
Hi,We have a user when they log into Finesse they receive "Error loading report", message. Do anyone know why this user is receiving this error? Screenshot attached below. Any assistance would be greatly appreciated. Thanks,
Hi All,I wonder if any of you have increased the vRAM on your UCCE Rogers/Aw-HDS beyond the prescribed by OVA numbers? I.e. if Rogger is said to have 6GB by the OVA can I make it 8?  SQL is eating memory plus there is some other management and securi...
Engnr by Level 1
  • 207 Views
  • 3 replies
I have script with toll free number(sip) the caller sometimes hear all audio prompts in menu, and sometime hear some audio prompts which not stable, but when I dial internally the trigger it is stable and I can hear all audio prompts in menu, What co...
matee by Level 1
  • 251 Views
  • 2 replies
Hi, We have some scripts that send a call redirect to a user's voicemail greeting and this works fine, using the call redirect step (destination = VM pilot, Called address reset to user's Ext.).The current set up from CUCM to Unity is SCCP, and I've ...
We have many calls consider as abandoned due to caller hang-up, how I can make the calls consider abandoned if ring on agent more than 10sec, and if the calls ring on agent less than 10sec not consider as abandoned, because many calls hang-up after r...
matee by Level 1
  • 196 Views
  • 3 replies
Greetings, Can you provide the URL and Body example to update a campaign via the Outbound API.  I am able to Create Campaign, Get Campaign Definition, Get Campaign Records, Import Campaign Records, Delete Campaign Records, and Delete Campaign, but th...
galguire by Level 4
  • 1030 Views
  • 5 replies
A customer reports that contact center agents sometimes get a 403 Forbidden when trying to log into the desktop. This error resolves itself on its own after around a few hours; without going deep into troubleshooting, can someone give me a few hints ...
pescla by Spotlight
  • 118 Views
  • 2 replies
