ASA 5510 VPN problem
thotsaphon Wed, 06/18/2008 - 08:18
  • Gold, 750 points or more
Could you please remove a "nat (inside) 0 0.0.0.0 0.0.0.0" command and put "sysopt connection permit-ipsec" for testing?
Thot
nomair_83 Thu, 06/19/2008 - 02:28
  • Bronze, 100 points or more
In your nat0 acl..just swap the networks .(your vpn pool address should be destination)
and call that access-list in nat.
check sysopt and nat-t as well.
and remove nat (inside) 0 0.0.0.0 0.0.0.0
Farrukh Haroon Thu, 06/19/2008 - 03:29
  • Red, 2250 points or more
There is no need to remove nat (inside) 0 0.0.0.0 0.0.0.0 if the proper nat 0 ACL is there. NAT Exemption (nat 0 ACL) has the highest priority and will be consider first.
sysopt is enabled by default (but worth the check).
He is not using the nat ACL you refer to (nat_0), this one is being used which seems correct:
access-list inside_nat0_inbound extended permit ip any 192.168.50.0 255.255.255.192
nat (inside) 0 access-list inside_nat0_inbound
Farrukh
nomair_83 Thu, 06/19/2008 - 04:44
Can u mention some lan subnet in your no nat ACL instead of "any".
Just try If it works because "any" should also work.
