Configuring ATM interface (RFC2684)
Jun 18th, 2008
I need to configure a HWIC-1ADSL card to work MPoA. The Telco has given me the next data:
Modo de Acesso: MPoA (RFC 2684)
Tipo de Encapsulamento: LLC SNAP
VPI: 0
VCI: 37
WAN IP: A.B.C.D/255.255.255.252
My config is:
bridge irb
interface ATM0/3/0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0/3/0.1 point-to-point
no snmp trap link-status
bridge-group 2
pvc 0/37
encapsulation aal5snap
interface BVI2
ip address A.B.C.D 255.255.255.252
ip nat outside
ip virtual-reassembly
bridge 2 protocol ieee
bridge 2 route ip
It does not work. How can I see if the config is right?
Thanks.
Overall Rating: 4 (1 ratings)
paolo bevilacqua Wed, 06/18/2008 - 07:07
  • Hall of Fame,
    Founding Member
Hi, that should work. Check first if layer 1 is up with "show dsl interface".
victorgarciaternero Wed, 06/18/2008 - 07:29
Hi, this is the output of "sh dsl interface" command:
ATM0/3/0
Alcatel 20190 chipset information
ATU-R (DS) ATU-C (US)
Modem Status: Showtime (DMTDSL_SHOWTIME)
DSL Mode: ITU G.992.5 (ADSL2+) Annex A
ITU STD NUM: 0x03 0x2
Chip Vendor ID: 'STMI' 'BDCM'
Chip Vendor Specific: 0x0000 0x618F
Chip Vendor Country: 0x0F 0xB5
Modem Vendor ID: 'CSCO' ' '
Modem Vendor Specific: 0x0000 0x0000
Modem Vendor Country: 0xB5 0x00
Serial Number Near: FOC11213DAQCISCO73993206
Serial Number Far:
Modem Version Near: 12.4(11)T4
Modem Version Far:
Capacity Used: 13% 100%
Noise Margin: 38.0 dB 8.0 dB
Output Power: 17.0 dBm 12.0 dBm
Attenuation: 24.0 dB 8.0 dB
Defect Status: None None
Last Fail Code: None
Watchdog Counter: 0x61
Watchdog Resets: 0
Selftest Result: 0x00
Subfunction: 0x00
Interrupts: 185965437 (0 spurious)
PHY Access Err: 0
Activations: 1
LED Status: OFF
LED On Time: 0
LED Off Time: 0
Init FW: init_AMR-R-2.5.042_no_bist.bin
Operation FW: AMR-R-2.5.042.bin
FW Source: embedded
FW Version: 2.5.42
DS Channel1 DS Channel0 US Channel1 US Channel0
Speed (kbps): 0 2045 0 1020
Cells: 0 969 0 20546291
Reed-Solomon EC: 0 0 0 0
CRC Errors: 0 0 0 0
Header Errors: 0 0 0 0
Total BER: 0E-0 0E-0
Leakage Average BER: 0E-0 0E-0
Interleave Delay: 0 0 0 0
LOM Monitoring : Disabled
DMT Bits Per Bin
000: 0 0 0 0 0 0 0 7 9 A A B C C C C
010: C C C C D C C C B B B B A A A 9
020: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
030: 0 0 0 0 0 0 0 0 0 2 2 2 2 2 2 2
040: 2 2 2 2 2 2 2 2 2 2 2 2 4 4 2 2
050: 2 2 2 2 3 4 4 2 2 4 2 2 4 2 4 4
060: 4 2 4 4 4 4 4 4 4 2 4 4 4 4 2 4
070: 4 4 2 4 2 4 2 2 2 4 2 4 2 2 2 4
080: 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2
090: 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2
0A0: 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2
0B0: 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2
0C0: 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2
0D0: 2 2 2 2 2 2 2 2 2 0 0 0 0 0 0 0
0E0: 0 0 0 0 0 2 2 2 0 2 2 0 2 2 2 2
0F0: 0 2 2 2 2 2 4 4 2 2 4 2 4 4 4 2
100: 2 4 4 4 4 4 4 4 4 4 4 4 2 2 2 2
110: 2 2 2 2 2 2 2 2 3 2 4 2 2 2 2 2
120: 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2
130: 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2
140: 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2
150: 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2
160: 2 2 0 2 0 0 0 0 0 0 0 0 0 0 0 0
170: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
180: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
190: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1A0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1B0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1C0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1D0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1E0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
DSL: Training log buffer capability is not enabled
Could be a problem with routing? Now I have the connection with the Telco through ethernet, so there is a default route ("ip route 0.0.0.0 0.0.0.0 dialer0"). If I type "ip route 0.0.0.0 0.0.0.0 bvi2" 50% of packets are lossed (it makes load-balancing between the two interfaces).
Thanks. Regards.
paolo bevilacqua Wed, 06/18/2008 - 07:48
  • Hall of Fame,
    Founding Member
Hi, remove dialer interface if you have any, and remove both default routes referencing interfaces, instead put one with the IP of the other valid address on your /30 wan subnet.
That should get you going. I haven't asked about default route because often the card doesn't connected at all and needs FW update. If you want to benefit from the updates too the url is:
ftp://ftp.cisco.com/pub/access/800
The one you want is 3-0-3 and there is a doc about.
victorgarciaternero Wed, 06/18/2008 - 08:46
Hi Paolo,
I have done all you say, and it doesn't work. Is there any debug command where I could see what is happening? Thanks
Best Regards.
paolo bevilacqua Wed, 06/18/2008 - 09:02
  • Hall of Fame,
    Founding Member
Post the last byte of you given IP so we can check the address for default route and ping.
victorgarciaternero Wed, 06/18/2008 - 09:16
The last byte of our public ip is 126. The default gateway is 125. What test can I do?
paolo bevilacqua Wed, 06/18/2008 - 09:44
  • Hall of Fame,
    Founding Member
Ping default gw and check: "show ip route 0.0.0.0", "show atm pvc 0/37", "show bridge 2 verbose".
If the circuit was working with another router, you might need to clone mac of the working device in case it's cached somewhere.
Also check with telco that your circuit is fully activated, as sometime they forget to do so. In some networks, when you're activated for the first time, you can initially access a certain address via web only for registration, check if that is your case.
victorgarciaternero Wed, 06/18/2008 - 10:07
I think the route table is right. The output of "show atm pvc 0/37":
Description: N/A
ATM0/3/0.1: VCD: 6, VPI: 0, VCI: 37
UBR, PeakRate: 1020 (2406 cps)
AAL5-LLC/SNAP, etype:0x0, Flags: 0xC20, VCmode: 0x0, Encapsize: 12
OAM frequency: 0 second(s), OAM retry frequency: 1 second(s)
OAM up retry count: 3, OAM down retry count: 5
OAM END CC Activate retry count: 3, OAM END CC Deactivate retry count: 3
OAM END CC retry frequency: 30 second(s),
OAM SEGMENT CC Activate retry count: 3, OAM SEGMENT CC Deactivate retry count: 3
OAM SEGMENT CC retry frequency: 30 second(s),
OAM Loopback status: OAM Disabled
OAM VC Status: Not Managed
ILMI VC status: Not Managed
InARP frequency: 15 minutes(s)
InPkts: 52, OutPkts: 134, InBytes: 3744, OutBytes: 6325
InPRoc: 52, OutPRoc: 0, Broadcasts: 134
InFast: 0, OutFast: 0, InAS: 0, OutAS: 0
InPktDrops: 0, OutPktDrops: 0/0/0 (holdq/outputq/total)
CrcErrors: 0, SarTimeOuts: 0, OverSizedSDUs: 0, LengthViolation: 0, CPIErrors: 0
Out CLP=1 Pkts: 0
OAM cells received: 0
F5 InEndloop: 0, F5 InSegloop: 0,
F5 InEndcc: 0, F5 InSegcc: 0, F5 InAIS: 0, F5 InRDI: 0
F4 InEndloop: 0, F4 InSegloop: 0, F4 InAIS: 0, F4 InRDI: 0
OAM cells sent: 0
F5 OutEndloop: 0, F5 OutSegloop: 0,
F5 OutEndcc: 0, F5 OutSegcc: 0, F5 OutAIS: 0, F5 OutRDI: 0
F4 OutEndloop: 0, F4 OutSegloop: 0, F4 OutRDI: 0
OAM cell drops: 0
Status: UP
The output of "show bridge 2 verbose" is:
Total of 300 station blocks, 300 free
Codes: P - permanent, S - self
Flood ports (BG 2) RX count TX count
ATM0/3/0.1 0 0
Thank you very much Paolo,
Regards.
paolo bevilacqua Wed, 06/18/2008 - 10:48
  • Hall of Fame,
    Founding Member
That all seems fine. Can you ping the default gw ? If so, have you configure ip nat inside and globally with an ACL ?
victorgarciaternero Wed, 06/18/2008 - 23:03
Hi Paolo, I can't ping the default gateway. I have configured nat, but it was working well with the other connection. No ACL is configured. Any idea?
Best Regards.
paolo bevilacqua Thu, 06/19/2008 - 09:13
  • Hall of Fame,
    Founding Member
Ok, try:
no interface BVI2
no bridge-group 2
ip nat inside source list 1 interface ATM0/3/0.1 overload
Replace ACL 1 with whatver number you've configured for NAT.
