SSL config
Jun 18th, 2008
Dear Sir,
I have a pair of 11501, which load balance two SSL server behind them. The cert is stored in SSL server(10.106.13.20 & 21). The external vip is 10.106.13.224.
I read the SSL Config Gide and made the below configuration. Can you check if my config below is ok?
ssl-proxy-list PIS-SSL-LIST
backend-server 1
backend-server 1 type backend-ssl
backend-server 1 ip address 10.106.13.224
backend-server 1 server-ip 10.106.13.20
backend-server 1 version ssl3
backend-server 1 session-cache 300
backend-server 1 tcp virtual ack-delay 0
backend-server 2
backend-server 2 type backend-ssl
backend-server 2 ip address 10.106.13.224
backend-server 2 server-ip 10.106.13.21
backend-server 2 version ssl3
backend-server 2 session-cache 300
backend-server 2 tcp virtual ack-delay 0
active
service PIS-SSL-SERVICE
type ssl-accel-backend
add ssl-proxy-lit PIS-SSL-LIST
active
owner PIS-SSL-OWNER
content PIS-SSL-VIP-1
vip adddress 10.106.13.224
port 80
advanced-balance arrowpoint-cookie
url "/*"
add service PIS-SSL-SERVICE
active
Overall Rating: 4 (1 ratings)
Gilles Dufour Sun, 06/22/2008 - 22:17
  • Cisco Employee,
this is totally wrong unfortunately.
What are you trying to achieve here ?
Normally the connection between CSS and server does not need to be encrypted because they are close to each other.
You probably want to encrypt the connection from the client to the CSS since this connection goes throug the Internet.
Is this what you need ?
Here are sample configs:
http://www.cisco.com/en/US/docs/app_ntwk_services/data_center_app_services/css11500series/v8.10/configuration/ssl/guide/examples.html#wp999094
backend-ssl is @
SSL Transparent Proxy Configuration - HTTP and Back-End SSL Servers
You will see that you did many mistakes, like ip addresses used in the ssl-proxy-list.
Gilles.
