WLC 4402 with 1231g
Jun 18th, 2008
Hi!
I got a problem with a LWAPP 1231 and 4402 WLC. The convertion procedure goes fine, but when the AP tries to join to controller i find some errors on the AP and does not register on the WLC.
Errors on the AP:
*Mar 1 00:00:23.718: %LWAPP-5-CHANGED: LWAPP changed state to DISCOVERY
Mar 1 00:00:34.383: %LWAPP-5-CHANGED: LWAPP changed state to JOIN
Mar 1 00:00:40.395: LWAPP_CLIENT_ERROR_DEBUG: spamHandleJoinTimer: Did not rec
ieve the Join response
*Mar 1 00:00:40.395: LWAPP_CLIENT_ERROR_DEBUG: No more AP manager IP addresses remain.
Mar 1 00:00:40.447: %SYS-5-RELOAD: Reload requested by LWAPP CLIENT. Reload Reason: DID NOT GET JOIN RESPONSE.
*Mar 1 00:00:40.447: %LWAPP-5-CHANGED: LWAPP changed state to DOWNXmodem file s
ystem is available.
WLC version: AIR-WLC4400-K9-4-2-112-0.aes
AP version: c1200-rcvk9w8-tar.123-11JX1.tar
Hope it helps.
Thank you very much
Scott Fella Wed, 06/18/2008 - 15:06
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
Scott Pickles Thu, 06/19/2008 - 05:48
The AP 1231 is an older one, and probably has a Self-Signed Certificate (SSC). Newer APs have MIC, or Manufacture Installed Certificate. You need to enable SSC on the controller and add the certificate hash to the controller to allow it to join. The certificate hash should have been given to you as an output file from the upgrade process. Also, be sure your controller's time is current - I recommend an NTP server.
Scott
uosambela Tue, 06/24/2008 - 01:09
Hi guys!
Thanks for your posts.
I'll try it ASAP.
We'll keep in touch.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
