Site to Site VPN Error through CDM
Jun 18th, 2008
We are setting up a pt to pt vpn through the cisco cdm. We have tried everything under the sun to get this tunnel to the up status with no luck. The VPN troubleshooting Report passes everything except the tunnel being up. It reports There is no response from the peer VPN device. I have included the mirrors for review. Any help is much appreciated.
Mirror 1:
The mirror configuration should only be used as a guide when configuring the peer.
The following configuration MUST NOT be directly applied to the peer device.
crypto isakmp policy 1
authentication pre-share
encr 3des
hash sha
group 2
lifetime 86400
exit
crypto isakmp key password! address 24.x.x.15
crypto ipsec transform-set ESP-3DES-SHA1 esp-sha-hmac esp-3des
mode tunnel
exit
ip access-list extended SDM_2
remark SDM_ACL Category=4
remark IPSec Rule
permit ip 172.18.3.0 0.0.0.255 172.18.2.0 0.0.0.255
exit
crypto map SDM_CMAP_1 3 ipsec-isakmp
description Apply the crypto map on the peer router's interface having IP address 208.125.212.18 that connects to this router.
set transform-set ESP-3DES-SHA1
set peer 24.213.143.15
match address SDM_2
exit
Mirror 2:
encr 3des
hash sha
group 2
lifetime 86400
exit
crypto isakmp key password! address 208.125.212.18
mode tunnel
exit
remark IPSec Rule
permit ip 172.18.2.0 0.0.0.255 172.18.3.0 0.0.0.255
exit
description Apply the crypto map on the peer router's interface having IP address 24.213.143.15 that connects to this router.
set peer 208.x.x.18
match address SDM_2
exit
Mark Yeates Wed, 06/18/2008 - 16:45
  • Gold, 750 points or more
The problem is the ACL's for the IPsec tunnels do not match the physical interfaces of the VPN tunnels. I am not sure how your network is subnetted but if you used
permit ip 208.125.212.1 0.0.0.31 208.125.212.1 0.0.0.31
as "ip access-list extended SDM_2" everything should be fine. The rest of your crypto map looks good.
Hope this helps,
Mark
Mark Yeates Wed, 06/18/2008 - 17:37
Looking back over the config what are the IP addresses of the physical interfaces of the routers? You need to be able to allow both addresses for the interesting traffic to be allowed to pass the tunnel.
nexlevel315 Thu, 06/19/2008 - 09:22
Mark,
Thank you for your response! I have been pulling my hair out with this one. I knew the acl was missing something. One wan is 24.213.143.15 the other is 208.125.212.18 the subnets i can just replace with your example. I look forward to hearing from you!
Mark Yeates Thu, 06/19/2008 - 16:02
Here are the corrected ACL's that should get you going. I am naming these examples siteA and siteB to prevent confusion.
SiteA:24.213.143.15
SiteB:208.125.212.18
ip access-list extended SiteA
permit ip 24.213.143.15 0.0.0.0 208.125.212.18 0.0.0.0
ip access-list extended SiteB
permit ip 208.125.212.18 0.0.0.0 24.213.143.15 0.0.0.0
After applying these ACL's to the router make sure that you apply the ACL to crypto map. Let me know if this helps.
Mark
nexlevel315 Sun, 06/22/2008 - 08:25
Mr. Yeates,
Thank you again for your help. I was unsuccessful at bringing the tunnel up with this addition. Is there anyway you can walk me through setting the tunnel up at both ends through the SDM? i'd rather dump this and start from scratch. THanks!
Mark Yeates Sun, 06/22/2008 - 08:39
I am sorry to hear that it is not working. Here is a template that I wrote a while back that is a fill in the blank template that might help you.
nexlevel315 Mon, 06/23/2008 - 08:48
Again, I really appreciate your help!
I am not so familiar with the command line. I have recreated the 2 sides of the tunnel. Tunnel A(.2 network) is where i think the problem is. Tunnel B(.3 network) when using the vpn trouble shooter reports, "The peer 24.213.143.154 is responding but the VPN tunnel in not established. IPSec policies of this router are not matching with the IPSec policies of the peer device." here are the mirrors:
Tunnel A (.2)
encr 3des
hash sha
group 2
lifetime 86400
exit
crypto isakmp key !password address 24.213.143.151
crypto ipsec transform-set ESP-3DES-SHA esp-sha-hmac esp-3des
mode tunnel
exit
exit
description Apply the crypto map on the peer router's interface having IP address 208.125.212.181 that connects to this router.
set peer 24.213.143.151
match address SDM_2
exit
Tunnel B (.3)
encr 3des
hash sha
group 2
lifetime 86400
exit
crypto isakmp key !password address 208.125.212.181
crypto ipsec transform-set ESP-3DES-SHA11 esp-sha-hmac esp-3des
mode tunnel
exit
remark IPSec Rule
exit
description Apply the crypto map on the peer router's interface having IP address 24.213.143.151 that connects to this router.
set transform-set ESP-3DES-SHA11
set peer 208.125.212.181
match address SDM_2
exit
I have other tunnels active on both routers to other sites im not sure if those mirros would be helpful or not.
I also noticed that under the ip access-list in the above, tunnel A states remark ipsec rule as a line and tunnel B does not, just shooting in the dark here.
Mark Yeates Mon, 06/23/2008 - 11:09
Not a problem. I am familiar with the CLI and not SDM for VPN so I will do the best I can. The obvious issue is the ACL's are not pointing to each other. The ACL needs to permit the two interfaces (where the arrows are pointing) to talk to each other. The only other thing I would take out is the "tunnel mode" under your crypto ISAKMP policy 1.
(A)<------>(B)
Hope This helps,
mark
nexlevel315 Mon, 06/23/2008 - 12:27
Mark,
After looking into the running config, i see other access lists that deny the traffic we are trying to permit. I am curious as to the order these are run and if they have any bearingon our current project (the a to b tunnel). Here is a shot of the ACL's.
Building configuration...
Current configuration : 12308 bytes
version 12.3
service password-encryption
hostname Brittonfield
boot-start-marker
boot-end-marker
logging buffered 52000 debugging
aaa new-model
aaa authentication login default local
aaa authentication login sdm_vpn_xauth_ml_1 local
aaa authorization exec default local
aaa authorization network sdm_vpn_group_ml_1 local
aaa session-id common
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
ip cef
ip inspect name SDM_LOW cuseeme
ip inspect name SDM_LOW dns
ip inspect name SDM_LOW ftp
ip inspect name SDM_LOW h323
ip inspect name SDM_LOW https
ip inspect name SDM_LOW icmp
ip inspect name SDM_LOW imap
ip inspect name SDM_LOW pop3
ip inspect name SDM_LOW netshow
ip inspect name SDM_LOW rcmd
ip inspect name SDM_LOW realaudio
ip inspect name SDM_LOW rtsp
ip inspect name SDM_LOW esmtp
ip inspect name SDM_LOW sqlnet
ip inspect name SDM_LOW streamworks
ip inspect name SDM_LOW tftp
ip inspect name SDM_LOW tcp
ip inspect name SDM_LOW udp
ip inspect name SDM_LOW vdolive
no ip dhcp use vrf connected
no ip ips deny-action ips-interface
ip domain name domain.local
ip name-server 24.x.226.113
ip name-server 24.x.226.123
no ftp-server write-enable
crypto pki trustpoint TP-self-signed-399736215
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-399736215
revocation-check none
rsakeypair TP-self-signed-399736215
crypto pki certificate chain TP-self-signed-399736215
certificate self-signed 01
30820250 308201B9 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
30312E30 2C060355 04031325 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 33393937 33363231 35301E17 0D303731 32303531 34313434
325A170D 32303031 30313030 30303030 5A303031 2E302C06 03550403 1325494F
532D5365 6C662D53 69676E65 642D4365 72746966 69636174 652D3339 39373336
32313530 819F300D 06092A86 4886F70D 01010105 0003818D 00308189 02818100
AF212155 A68BB61A 7E4F1376 72BB1EF9 CFB38F59 56943CDA BB6762E0 2F5CA1CE
FF3C6795 0B75624E 96B0799C 8B5B8908 351B0EC5 CE6C23B5 F4513DF2 997CCF04
62DA3890 F0C1D585 2D1FCC18 29E22016 5E9AB128 6593515C 1F3B547D BF943482
2D891E47 399B4AC0 FE3AE4C9 0BDDEAB7 00F8B841 F117BEEB 4148AD6B D7434C65
02030100 01A37A30 78300F06 03551D13 0101FF04 05300301 01FF3025 0603551D
11041E30 1C821A42 72697474 6F6E6669 656C642E 636E7964 6961672E 6C6F6361
6C301F06 03551D23 04183016 8014F95A 7CA2031A B9BB3360 54AB107B E8403317
EF1F301D 0603551D 0E041604 14F95A7C A2031AB9 BB336054 AB107BE8 403317EF
1F300D06 092A8648 86F70D01 01040500 03818100 4E9C1CD0 1BDD7430 88ED22B5
B614270B 17397AFF F6F399BA 12D5121B B4F20A0E DD9A9B85 A10768CB 52995D83
58308897 9B7A5E1D 5ADCCF9E 8638A835 56FEA126
quit
username xxx privilege 15 secret xxx
encr 3des
group 2
crypto isakmp key password address 208.125.212.211 no-xauth
crypto isakmp key password address 208.125.212.171
crypto isakmp key password address 208.125.212.181
crypto isakmp xauth timeout 15
crypto isakmp client configuration group cadstream_remote
key !scanner%01
dns 10.121.1.114
pool VPN_IPpool
acl 104
crypto isakmp client configuration group confirma
key xxx
dns 10.121.1.115
pool VPN_IPpool
acl 104
next post...
nexlevel315 Mon, 06/23/2008 - 12:29
...continued
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-3DES-SHA1 esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-3DES-SHA2 esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-3DES-SHA3 esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-3DES-SHA4 esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-3DES-SHA5 esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-3DES-SHA6 esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-3DES-SHA7 esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-3DES-SHA8 esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-3DES-SHA9 esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-3DES-SHA10 esp-3des esp-sha-hmac
crypto dynamic-map SDM_DYNMAP_1 1
set transform-set ESP-3DES-SHA3
reverse-route
crypto map SDM_CMAP_1 client authentication list sdm_vpn_xauth_ml_1
crypto map SDM_CMAP_1 isakmp authorization list sdm_vpn_group_ml_1
crypto map SDM_CMAP_1 client configuration address respond
crypto map SDM_CMAP_1 1 ipsec-isakmp
description ### Tunnel to South beach ###
set peer 208.125.212.211
match address 103
crypto map SDM_CMAP_1 2 ipsec-isakmp
description Tunnel to208.125.212.171
set peer 208.125.212.171
set transform-set ESP-3DES-SHA4
match address 105
description Tunnel to208.125.212.181
match address 107
interface FastEthernet0/0
description ### LAN - Brittonfield ###
ip address 172.18.2.1 255.255.255.0
ip access-group 100 in
ip inspect SDM_LOW in
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
description ### WAN - Runner ###$ETH-WAN$
ip address 24.213.143.151 255.255.255.252
ip access-group 102 in
ip verify unicast reverse-path
ip inspect SDM_LOW out
ip nat outside
speed 100
full-duplex
interface FastEthernet0/0/0
description ### network - Access Port ###
no ip address
interface FastEthernet0/0/1
switchport access vlan 2
no ip address
interface FastEthernet0/0/2
no ip address
interface FastEthernet0/0/3
no ip address
interface Vlan1
description ### Interface to Itentive ###$FW_OUTSIDE$
ip address 10.121.16.112 255.255.255.0
ip access-group 101 in
ip nat inside
interface Vlan2
ip address 149.98.213.111 255.255.255.0
next post
nexlevel315 Mon, 06/23/2008 - 12:31
continued 2....
ip local pool VPN_IPpool 172.16.77.197 172.16.77.12
ip classless
ip route 0.0.0.0 0.0.0.0 24.213.143.151 name Default
ip route 10.121.0.0 255.255.0.0 10.121.16.1 name Itentive
ip route 149.98.213.0 255.255.255.0 10.121.16.1 permanent
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source route-map SDM_RMAP_1 interface FastEthernet0/1 overload
access-list 1 remark For NAT to Internet
access-list 1 remark SDM_ACL Category=16
access-list 1 permit 172.18.2.0 0.0.0.255
access-list 1 permit 10.121.16.0 0.0.0.255
access-list 23 permit 172.18.0.0 0.0.255.255
access-list 100 remark Inbound access list on LAN Interface
access-list 100 remark SDM_ACL Category=17
access-list 100 deny ip 10.121.1.0 0.0.0.255 any
access-list 100 permit icmp any host 172.18.2.1
access-list 100 deny ip 10.0.0.0 0.255.255.255 any
access-list 100 deny ip 192.168.0.0 0.0.255.255 any
access-list 100 deny ip 127.0.0.0 0.255.255.255 any
access-list 100 deny ip host 255.255.255.255 any
access-list 100 deny ip host 0.0.0.0 any
access-list 100 permit ip any any
access-list 101 remark Inbound access list on Itentive Interface
access-list 101 deny ip 172.18.2.0 0.0.0.255 any
access-list 101 permit icmp any host 10.121.16.2
access-list 101 deny ip 172.16.0.0 0.15.255.255 any
access-list 101 deny ip 192.168.0.0 0.0.255.255 any
access-list 101 deny ip 127.0.0.0 0.255.255.255 any
access-list 101 deny ip host 255.255.255.255 any
access-list 101 deny ip host 0.0.0.0 any
access-list 101 permit ip any any
next post...
nexlevel315 Mon, 06/23/2008 - 12:32
continued 3....
access-list 102 remark Inbound access list on Outside interface
access-list 102 remark SDM_ACL Category=17
access-list 102 permit udp host 208.125.212.181 host 24.213.143.151 eq non500-isakmp
access-list 102 permit udp host 208.125.212.181 host 24.213.143.151 eq isakmp
access-list 102 permit esp host 208.125.212.181 host 24.213.143.151
access-list 102 permit ahp host 208.125.212.181 host 24.213.143.151
access-list 102 remark IPSec Rule
access-list 102 permit ip 172.18.4.0 0.0.0.255 172.18.2.0 0.0.0.255
access-list 102 permit udp host 208.125.212.171 host 24.213.143.151 eq non500-isakmp
access-list 102 permit udp host 208.125.212.171 host 24.213.143.151 eq isakmp
access-list 102 permit esp host 208.125.212.171 host 24.213.143.151
access-list 102 permit ahp host 208.125.212.171 host 24.213.143.151
access-list 102 permit ip 172.16.77.91 0.0.0.7 172.18.2.0 0.0.0.255
access-list 102 permit ip 172.16.77.91 0.0.0.7 172.16.77.91 0.0.0.7
access-list 102 permit ip 172.16.77.91 0.0.0.7 149.98.213.0 0.0.0.255
access-list 102 permit ip 172.16.77.91 0.0.0.7 10.121.0.0 0.0.255.255
access-list 102 permit udp host 208.125.212.211 host 24.213.143.151 eq non500-isakmp
access-list 102 permit udp host 208.125.212.211 host 24.213.143.151 eq isakmp
access-list 102 permit esp host 208.125.212.211 host 24.213.143.151
access-list 102 permit ahp host 208.125.212.218 host 24.213.143.151
access-list 102 permit ip 172.18.1.0 0.0.0.255 172.18.2.0 0.0.0.255
access-list 102 permit udp any host 24.213.143.151 eq non500-isakmp
access-list 102 permit udp any host 24.213.143.151 eq isakmp
access-list 102 permit esp any host 24.213.143.151
access-list 102 permit ahp any host 24.213.143.151
access-list 102 deny ip 10.121.16.0 0.0.0.255 any
access-list 102 deny ip 172.18.2.0 0.0.0.255 any
access-list 102 permit icmp any host 24.213.143.151
access-list 102 deny ip 10.0.0.0 0.255.255.255 any
access-list 102 deny ip 172.16.0.0 0.15.255.255 any
access-list 102 deny ip 192.168.0.0 0.0.255.255 any
access-list 102 deny ip 127.0.0.0 0.255.255.255 any
access-list 102 deny ip host 255.255.255.255 any
access-list 102 deny ip host 0.0.0.0 any
access-list 102 deny ip any any log
access-list 102 permit ip 172.18.3.0 0.0.0.255 172.18.2.0 0.0.0.255
access-list 103 remark SDM_ACL Category=4
access-list 103 remark IPSec Rule
access-list 103 permit ip 172.18.2.0 0.0.0.255 172.18.1.0 0.0.0.255
access-list 104 remark ### Access list for remote VPN users ###
access-list 104 remark SDM_ACL Category=20
access-list 104 permit ip 172.18.2.0 0.0.0.255 172.16.77.91 0.0.0.7
access-list 105 remark SDM_ACL Category=4
access-list 105 remark IPSec Rule
access-list 105 permit ip 172.18.2.0 0.0.0.255 172.18.4.0 0.0.0.255
access-list 107 remark SDM_ACL Category=4
access-list 107 permit ip 172.18.2.0 0.0.0.255 172.18.3.0 0.0.0.255
access-list 110 remark SDM_ACL Category=2
access-list 110 deny ip 172.18.2.0 0.0.0.255 172.18.3.0 0.0.0.255
access-list 110 remark IPSec Rule
access-list 110 deny ip 172.18.2.0 0.0.0.255 172.18.4.0 0.0.0.255
access-list 110 deny ip 172.18.2.0 0.0.0.255 172.16.77.91 0.0.0.7
access-list 110 deny ip 149.98.213.0 0.0.0.255 172.16.77.91 0.0.0.7
access-list 110 deny ip 10.121.0.0 0.0.255.255 172.16.77.91 0.0.0.7
access-list 110 deny ip 172.18.2.0 0.0.0.255 172.18.1.0 0.0.0.255
access-list 110 permit ip 10.121.16.0 0.0.0.255 any
access-list 110 permit ip 172.18.2.0 0.0.0.255 any
route-map SDM_RMAP_1 permit 1
match ip address 110
control-plane
end
rpratapa Mon, 06/30/2008 - 07:27
hi,
I feel from the above ACL config, the interesting traffic is being blocked from entering the external ( WAN ) interface of the tunnel.
If I am not wrong, 172.18.3.0/ 24 and 172.18.2.0/24 form the interesting traffic for the tunnel and that's being dropped at the WAN interface.
1. Try to move this line above the start of "deny" statements.
2. Fire up the tunnel and look for the error log on the VPN gateway.
From the logs we can understand what actually the problem is.
Hope this helps.
-rk
Mark Yeates Mon, 06/23/2008 - 15:14
You seem to be OK with your ACL 102 inbound. Did you try the ACL that I recommended before?
no access-list 103
access-list 103 remark VPN ACL
access-list 103 permit ip host 208.125.212.171 host 24.213.143.151
and on the peer side
no access-list 103
access-list 103 permit ip host 24.213.143.151 host 208.125.212.171
Having the config to look at helps.
Mark
nexlevel315 Wed, 06/25/2008 - 06:42
Mark,
I added the permit hosts and still no luck.I have another idea that i would like your help with. This is extremely time sensitive and since we can't get the tunnel up i want to try this approach. we have current tunnels like this:
SiteA >> SiteC
SiteB >> SiteC
what would i need to do to pass the traffic from a to b through c?
SiteA: 172.18.2.0
SiteB: 172.18.3.0
SiteC: 172.18.1.0
can i just ad permit 172.18.3.0 to 172.18.2.0 on the 172.18.1.0 acl?
or do i ad static routes? if so, what should they look like?
nexlevel315 Wed, 06/25/2008 - 11:15
I added into static route into the .3 router
172.18.2.0 172.18.1.1
into the .2 router
172.18.3.0 172.18.1.1
my understanding is that this will send any traffic requests for the .2/.3 network to the 1.1 router, which i would think could route that appropriately.
pings time out from .2/.3 going to the respective network. Any ideas?
Mark Yeates Wed, 06/25/2008 - 16:33
Have you identified if the tunnels are up yet?
what is the output of
"show crypto sessions"
Or
"show crypto isakmp sa"
We are looking for up/up. After the tunnels are up then we can work on the routing of traffic across the tunnels.
nexlevel315 Fri, 06/27/2008 - 09:14
Mark,
We have been unsuccessful at bringing the tunnels up. i was trying to come up with a work around to pass the traffic since we have tunnels up to a central location. It is time sensitive and we have been beating our heads at the tunnels. I assumed that since both sites have up tunnels to a central site, that we could pass the traffic that way. that is where my static route idea came into play. Would you be interested in doing a remote session over the telephone to assist me with this?
Mark Yeates Fri, 06/27/2008 - 21:09
I am more than willing to help you (if time permits). Looking back at your configs I see that you are using private IP space for your internal network. There is no way to make this work without a tunnel of some sort. A work around would be to NAT to make this work, and will require much more work than it would be to get your VPN tunnels up and working. I do understand time is not on your side. Shoot me your email address and I'll do my best to help you out.
Mark
nexlevel315 Mon, 06/30/2008 - 05:56
matt [at] nexlevelnet [dot] com
I really appreciate your help. I would like to discuss this further so please e-mail me as soon as time permits. thanks!
