802.1Q trunking Aironet 1310
Jun 18th, 2008
hi,
my name is Filippo...i'm a new user..sorry for my english. I have a problem with 2 aironet 1310 in role root and non root without configuring VLAN because i must associate other bridge 350 on root station.
the question is: i'm unable to ping host whit different VLAN1 assigned to interface BVI1. the radio schema is:
Switch2----BRIDGE Root<--->BRIDGE non-root--Switch1 VLAN1..VLAN172
Switch1:
interface FastEthernet0/46
description to bridge non-root
switchport trunk allowed vlan 1,2,60,70
switchport mode trunk
no snmp trap link-status
spanning-tree portfast trunk
end
BRIDGE non-root:
dot11 ssid kerberosisa
authentication open
guest-mode
infrastructure-ssid optional
bridge irb
interface Loopback0
no ip address
no ip route-cache
interface Dot11Radio0
no ip address
no ip route-cache
encryption key 1 size 128bit 7 SECURE transmit-key
encryption mode wep mandatory
ssid kerberosisa
station-role non-root bridge
world-mode dot11d country IT both
bridge-group 1
no ip address
no ip route-cache
full-duplex
bridge-group 1
interface BVI1
ip address 10.1.1.101 255.255.255.0
no ip route-cache
ip default-gateway 10.1.1.1
ip http server
ip http secure-server
bridge 1 protocol ieee
bridge 1 route ip
BRIDGE root:
authentication open
bridge irb
no ip address
no ip route-cache
ssid kerberosisa
station-role root bridge
bridge-group 1
no ip address
no ip route-cache
full-duplex
bridge-group 1
interface BVI1
ip address 10.1.1.103 255.255.255.0
no ip route-cache
ip http server
bridge 1 route ip
Switch2:
interface FastEthernet0/1
description Bridge Root
end
IOS ver. 12.3(2)JA4
the command 'sh spanning-tree root ' on BR-root is correct
Bridge group 1
Root ID Priority 32768
Address 0011.21f8.5700
Cost 59
Port 6 (Virtual-Dot11Radio0)
Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec
non-root
Bridge group 1
Cost 26
Port 3 (FastEthernet0)
is ok!
any idea? please...
TKS
Overall Rating: 5 (1 ratings)
rskrzek Thu, 06/26/2008 - 03:15
hi,
You must configure trunk on ethernet and dot11 interfaces on access point too, not only on switches. Now is bridged VLAN 1 (native) only
regards
romek
