WLC 4404 reboots (Crashed)
Jun 18th, 2008
I have a WLC4404 with the last release,, and it suddenly reboots
Anyone has the same situation?
moises.rodriguez Tue, 06/24/2008 - 14:08
Thanks, but the bug descriptionspecifies that it was fixed:
I supose that 5.0.148 is newer than 4.1.171
So? now I'm lost
kfccolonel Tue, 06/24/2008 - 19:01
With wireless, your looking at different trains of code between 4.1 and 5.0
Fixed in the 4.1 train does not mean fixed in the 5.0 train.
The bug would need to say it was fixed in the 5.0 train. Check the release notes in 5.0.148....there are a number of crash/reboot related bugs other than the one mentioned. For now, your options are to live with the bugs in 5.0 or downgrade to 4.2.130 and loose some features.
Scott Fella Tue, 06/24/2008 - 19:15
If you don't have 1252's to support, I would suggest using 4.1.185. If you want to use 4.2 then go with the latest 4.2. 5.0 has too many issues.
armonk_netdesk Wed, 06/25/2008 - 13:18
What is taking so long for a 5.0 code refresh? It came out in Feb and no interim updates yet to resolve some killer bugs.
Scott Fella Wed, 06/25/2008 - 13:21
Well the thing is that they are going to bring the mesh train back into the same code for 5.1. So I would say that 4.2 is your best bet until all the bugs from 5.0 and 5.1 are fixed.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
