IPM LMS 3.0
Jun 18th, 2008
i have install IPM application but is not working as expected,please does anyone have any material related to this that i can o thru.
Please reply thanks in advance,cheers.
sameoj1881 Thu, 06/19/2008 - 04:45
the problem am facing is that under IPM,tabs like Admin,Reports and Collector Management pages can`t be displayed.
Do you know what to do to restore this,please reply,thanks.
Farrukh Haroon Thu, 06/19/2008 - 04:09
  • Red, 2250 points or more
What is the problem you are facing?
Farrukh
sameoj1881 Thu, 06/19/2008 - 04:44
Farrukh Haroon Thu, 06/19/2008 - 05:15
page's cant be displayed = ?
Can you post a screen-shot.
Are other applications displaying fine? DFM,CS,CM?
Farrukh
sameoj1881 Thu, 06/19/2008 - 05:57
am having problems attaching the screen shot cos the size is above the max size for attachment.DFM is also behaving the same way "page cannot be displayed".
Can somebody please help me.
Farrukh Haroon Thu, 06/19/2008 - 05:59
Are all your CiscoWorks services running?
You can check this via CiscoWorks common services.
Farrukh
sameoj1881 Thu, 06/19/2008 - 06:28
Yes i have check all the vis common services>server>admin>processes,the process state for all is stated though some are yet to receive mgt message.
Do you think if i re-install the IPM it will work?
Please kindly help me,thanks.
Farrukh Haroon Thu, 06/19/2008 - 08:43
Try this:
net stop crmdmgtd
net start crmdmgtd
If this doesnt work, reboot.
If that does not work either, please let us know.
Farrukh
sameoj1881 Thu, 06/19/2008 - 08:51
I have uninstall and re-install,now am trying to do the settings,thanks.
