INBOUND CALL WITH SIP TRUNK
Jun 18th, 2008
Dear Experts,
i have a problem in my lab (AS4500XM with CCM5 -10.100.252.10- and SIP trunk). the problem is:
when i make call from the PSTN to our internal number i can not receive any call but i can make call to the outbound ,and below you can see the gateway cofiguration :
ip cef
isdn switch-type primary-net5
voice service voip
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback none
sip
bind control source-interface GigabitEthernet0/0
bind media source-interface GigabitEthernet0/0
!controller E1 7/0
pri-group timeslots 1-31
controller E1 7/1
controller E1 7/2
controller E1 7/3
controller E1 7/4
controller E1 7/5
ip address 10.100.252.120 255.255.255.0
duplex auto
speed auto
negotiation auto
interface Serial7/0:15
no ip address
encapsulation hdlc
no cdp enable
interface Serial7/1:15
no ip address
encapsulation hdlc
isdn incoming-voice modem
no cdp enable
interface Serial7/2:15
no ip address
encapsulation hdlc
no cdp enable
ip default-gateway 10.100.252.1
no ip http server
control-plane
voice-port 7/0:D
voice-port 7/1:D
voice-port 7/2:D
dial-peer voice 1 pots
destination-pattern 9T
port 7/1:D
dial-peer voice 2 voip
destination-pattern 2T
session protocol sipv2
session target ipv4:10.100.252.10
dtmf-relay rtp-nte h245-signal h245-alphanumeric
codec g711ulaw
Thanks all
jbyron Wed, 06/18/2008 - 10:55
Try enabling "header-passing" under sip under voice service voip.
Janet
AHMED Ali Wed, 06/18/2008 - 11:30
hello Islam
Check if you are receiving the correct digits from PSTN side, as I see in VG configuration it must starts by 2XXXXX
Use this debug command “debug voip ccapi inout”
Ahmed Rizk
islam.irshaid Wed, 06/18/2008 - 20:56
Thanks all
the problem was solved by using "incoming called-number ." and "direct-inward-dial" under DP 1
