auto attandent
Jun 18th, 2008
hi,
we have cisco call manager business edition 6.1 that is intergrated with cisco unity connection 2.1
i need to configure auto attendant.
when caller call the extension 400 they hear gretting ( press one foe sale, press 2 for cistomer, press for administration)
and behind "1" it have the extension 100
and behind "2" 200 and behind "3" 140
please help, i opned the tac with numberSR 608670081 but no solutin.
testeven Wed, 06/18/2008 - 10:29
  • Cisco Employee,
Hi!
To configure AA you will need to create Call Handlers on CUC. Basically you will have a CTI RP on CCM that matches a DID number to send calls to a CUC Call Handler, play greetings and allow caller inputs.
Basic steps are:
1. On CUCM create a CTI RP with extension XXXX and Call Forward All to VM.
2. On CUC go to Call Management--> System Call Handlers--> create a Call Handler with extension XXXX (use the one above)
3. Edit--> Greetings --> Standard--> Play/Record -->There you can record a greeting instructing the caller to press 1 for X, 2 for Y, etc
4. Edit--> Caller Input--> Configure each key (1,2,etc) to forward the call to another CH to listen to a greeting or to send the caller
to a subscriber depending on your needs.
For more info please refer to:
*** System Administration Guide for Cisco Unity Connection Release 2.x ***
--> Managing Call Handlers
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/2x/administration/guide/2xcucsag060.html
Please rate this post if it was useful :)
Tere.
said19770 Thu, 06/19/2008 - 03:45
Hi testeven,
1-i configured CTI with extension 400 and the calls is forwarded all to voice mail.
2- i created a call handler "omp" with extension 400.
and input 1 to call handler admin1 (351)
input 2 to callhandler admin2(352) and input 3 to callhandler admin3(353).
i have created call handler admin& and admin2 and admin3.
but the auto attandent don't work
testeven Thu, 06/19/2008 - 08:20
  • Cisco Employee,
What do you mean by the AA doesn't work?
Does the call reach Unity? Are you able to hear the greeting for the omp CH?
said19770 Mon, 06/23/2008 - 00:54
hi,
whene I call 400, i hear the gretting " cisco unity connection .....")i don't hear the gretting for the omp CH
Jaime Valencia Mon, 06/23/2008 - 18:50
  • Cisco Employee,
  • Hall of Fame,
    2011
configure a call routing rule on which the dialed number is 400 and send it to the call handler which you created
javalenc
if this helps, please rate
said19770 Sat, 07/12/2008 - 09:39
hi ,
whene i have created the rule i can hear the gretting for call handler, but this work for some time ( 3 hours), and become dowon( i hear " busy tonne"), whene i relod the CUC, it works for some time and becom down again.
please help
arshad.dhunna Mon, 08/04/2008 - 00:42
This could be definetly bug otherwise it should work but creating routing rules.
Thks
