06-18-2008 10:03 AM - last edited on 03-25-2019 07:42 PM by ciscomoderator
Dear all,
During some months CAR has loaded the CDRs of my ccm6.0 cluster without any problem. this was the CDR load configuration in CAR
Load CDR & CMR
Time 22.15
Loading interval Every 24hours
Duration 10 minutes
Uninhibited Loading
From 00.00
to 07.00
But this Monday I change this configuration. I restarted in the Publisher the 3 services related with CDRs.
Since then no CDR has been loaded in the system.
In CAR --> System --> Log I can see that since the day I changed this the CDR load is tried as I have configured but it is Unsuccessful.
I have tried the Real Time loading for 1hour but it doesn't load any CDR.
What could be the problem? What can I do to solve it?
Thanks in advance for your kind help, it is quite urgent for me to solve it.
06-24-2008 01:51 PM
CDR files cannot be sent to CDR Repository directories due to the fact that CDR Agent is denied local SFTP permission. If CallManager runs on a different server, CDR Agent will be able to send CDR file to CDR Repository node.
You can also refer the bug CSCsl69542.
06-24-2008 04:05 PM
have you already restarted the CDR and DBL services?
javalenc
if this helps, please rate
06-24-2008 11:42 PM
Yes, I restarted the services.
In fact we restarted all the nodes of the cluster
