Network Assitantt V5, read config-archive off line?
Jun 18th, 2008
Is there a way to open the archived files off line of the switch that created them?
I have tried opening the switch-config-archive.jar file directly using both the Network Assistant software and with a text editor but am unable to do so.
Direct connection to the switches to query config is not possible.
John
aghaznavi Tue, 06/24/2008 - 13:39
  • Silver, 250 points or more
Use the show archive log config {all | number [end-number] | user username [session number] number [end-number] | statistics} [provisioning] privileged EXEC command to display the complete configuration log or the log for specified parameters.
http://www.cisco.com/en/US/docs/switches/blades/3110/software/release/12.2_40_ex2/configuration/guide/swlog.html
