Vlan- access-group
Jun 18th, 2008
Please advice!!!!!
I have a 3560 switch, which is running 3560-advipservicesk9-mz.122-44.SE1.bin. I am not able to apply access-group under vlan interface. Is there any commands to do it? or use VLAN ACL is the only way?
thank you!
Jon Marshall Wed, 06/18/2008 - 12:53
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
What command are you using ?
For example if you have an access-list 101
int vlan 10
ip access-group 101
Jon
