Static entry on ASA
Answered Question
Jun 18th, 2008
Hello's,
I have a ASA running 7.2.
I'm trying to issue this command:
static (inside,outside) tcp 4.1.14.10 3389 192.168.0.5 3389 netmask 255.255.255.255 0 0
And keep getting this:
ERROR: Static PAT using the interface requires the use of the 'interface' keyword instead of the interface IP address
This is my first time messing with an ASA and I'm just trying to forward any traffic on port 3389 (RDP) to 192.168.0.5.
Help?
Correct Answer by Jon Marshall about 9 years 1 month ago
If 4.1.14.10 is the IP address assigned to the ASA outside interface change your static statement to
static (inside,outside) tcp interface 3389 192.168.0.5 3389 netmask 255.255.255.255
Jon
Overall Rating: 5 (1 ratings)
Correct Answer
Jon Marshall Wed, 06/18/2008 - 15:11
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Jon
Armegeden Wed, 06/18/2008 - 15:22
Gah!
Reading the error message, I tried "outside" instead of the word "interface". Syntax error.
Anyhow, did what you said + added ACL entry and everything working great.
Thanks so much for the fast response!
