Least Cost Routing VoIP between CME sites - can it be done?
Jun 18th, 2008
Is it possible to configure LCR between two CME sites? I have two different CME's that are in two different states and would like to take advantage of the PSTN connections at both sites. I'm currently using h323 dial-peers for 4-digit dialing and toll bypass, but am not quite sure how to get site A to dial out site B's ISDN line for PSTN calls.
I'm using CallManager Express at both sites.
Any hints?
Thanks.
Overall Rating: 4 (1 ratings)
Michael Owuor Wed, 06/18/2008 - 22:53
  • Cisco Employee,
Mike,
This can be done. Make the configuration transparent to the IP phone users, so they will just dial the numbers as long distance numbers. Configure redundancy via dial-peers. Two dial-peers will do the trick. The first dial-peer will send the call to the remote gateway for it to be routed out as a local call. If the number dialed is dialed as 91+10 digits, strip the 91 (and the area code if necessary) before sending the call to the remote gateway which should already be configured to route the call out as a local call. The second dial-peer is a failover dial-peer, to be used incase the WAN is down or the remote gateway is not available to route out the call. In this case, the call is sent out the local gateway as a normal long distance call.
The configuration could look somewhat like this:
voice translation-rule 4
rule 1 /^91212/ /212/
voice translation-profile LCR
translate called 4
dial-peer voice 1 voip
description ** LCR Via CME_Site_B **
destination-pattern 91212[2-9]......
translation-profile outgoing LCR
preference 1
dial-peer voice 2 pots
description ** LD to CME_Site_B Via Local PSTN**
preference 2
forward-digits 11
port x/x
Hope this helps.
Michael.
m-ketchum Thu, 06/19/2008 - 12:55
Michael,
Thanks for the quick reply and the suggestions.
It turns out that I was over complicating things by adding an incoming dial-peer at my far-end system. As soon as I removed that the incoming VoIP calls started routing out the PSTN.
I'll use your preference suggestions for failover dial-peers.
Thanks much,
Mike
Michael Owuor Thu, 06/19/2008 - 13:48
  • Cisco Employee,
You are welcome Mike. Good to hear that all is well in your VoIP world :-)
Michael.
Cecilia Joo Mon, 01/26/2015 - 04:05
Can you please refer to a configuration guide? I would need that quite urgently and I cannot find a general guide so far.
Thank you,
Cecilia
