Lab simulator question for the CCNA
Jun 18th, 2008
My name is Joe and I am currently studying for the CCNA exam and I wanted to know what is the best way to study for the simulator questions that are on the CCNA exam.
The most common is to make sure and read and have some type of experience on either virtual routers/switches (BOSON or BOSON like apps), purchase some low cost routers/switches from ebay and perform labs of your own, and/or rent rack time from different companies (fatkid, ccbootcamp,
If you cant create your own labs, just follow the book and make sure you know the fundamentals and do the same exact labs you see in the book so you understand exactly what the book is asking/saying.
sirdudesly Thu, 06/19/2008 - 01:27
Emulate (check out a project called GNS3 which uses dynamips to emulate IOS as opposed to simulate a couple of commands)
or buy.
If you don't want to do CCNP level stuff you can buy hardware to do most of the CCNA for fairly cheap off ebay. Personally I find using physical hardware easier.
