Remotely access a failover pair?
Jun 18th, 2008
Sorry for the simple question, but how can one remotely access the CLI for a failover unit in an ASA pair? If I SSH/Telnet into the address used, I get the primary unit...
Loading. Wed, 06/18/2008 - 20:40
You must use the IP address of the interface of the standby firewall.
I hope this helps.
Best regards.
fsmontenegro Thu, 06/19/2008 - 22:55
What interface address? The failover or state interfaces are not valid options for allowing SSH/Telnet on, and the data interfaces (inside, outside, etc...) don't have an IP address, since the unit is the standby.
I can see how a terminal server can be used to access the console port, but are there any options that don't rely on additional hardware?
uchideshi Thu, 06/19/2008 - 07:43
You can't unless you have a terminal server that will allow you console access to the standby unit. Using the standby's IP without a TS logs you on the active unit.
Farrukh Haroon Fri, 06/20/2008 - 03:33
No you can do this 'for sure'. You have to use the 'standby' IP address in order to achieve this.
interface gig 0/0
nameif inside
sec 100
ip address standby
Host-PC> telnet
