06-18-2008 09:55 PM - edited 07-03-2021 04:02 PM
I upgraded my WCS to 4.2. After that, everytime I want to configure an accesspoint, I get an error message ""Tertiary Controller Name: This attribute is MANDATORY. Please Specify it".
How can I turn that off? Thanks
Solved! Go to Solution.
06-22-2008 09:38 AM
Hi Tobias,
It sounds like this Bug has carried over;
CSCsi24972 Bug Details
Tertiary controller - need not be mandatory
Symptom:
WCS 4.1.83.0, with 3 or more WLC linked.
Attempt to modify the configuration of an AP and if you do not have a tertiary defined you get an error telling you that it is mandatory.
Conditions:
WCS 4.1.83. Status
Fixed
Severity
4 - minor
Last Modified
In Last 2 weeks
Product
Cisco Wireless Control System
Technology
1st Found-In
4.1(83.0)
Fixed-In
4.2(26.0)
Related Bug Information WCS 4.1.83.0 Requires Tertiary Controller be set for AP
Symptom: WCS 4.1.83.0, with 3 or more WLC linked. Attempt to modify the configuration of an AP and if you do not have a tertiary defined you get an error telling you that it is mandatory. Conditions: WCS 4.1.83.0, with 3 or more WLC linked Workaround: Define the secondary or primary as the tertiary <
Hope this helps!
Rob
06-19-2008 05:46 AM
Interesting....
I have not had this experience with my WCS in 4.2.x.
Do you have a 3rd controller? if not, have you tried just using the same controller for both primary and tertiary?
06-21-2008 04:42 AM
I too have not experienced that with WCS 4.2. I just tried creating a template and pushing that our with no tertiary. No problems here.
06-22-2008 09:38 AM
Hi Tobias,
Symptom:
Conditions:
WCS 4.1.83. Status
Fixed
Severity
4 - minor
Last Modified
In Last 2 weeks
Product
Technology
1st Found-In
4.1(83.0)
Fixed-In
4.2(26.0)
Hope this helps!
Rob
