SRST issue
Jun 18th, 2008
1. Call Manager Version: 6.0.1
2. SRST router: Cisco 3825
3. Router IOS version: 12.4 (15) T5
4. IP phones:
• CP-7940G firmware version 8.0(5.0)
• CP-7960G firmware version 8.0(5.0)
After configured the SRST:
The IP phones 7940 & 7960 are configured with two line, line 1 for CUG codec G729 and line 2 for PSTN calling codec G711.At the time of failover phones are getting registered to the SRST router and 'CCM fallback mode' is being displayed on the phones. But there is no dial tone on the phone or if we press the speaker key it glows and goes OFF immediately. At the same time the memory utilization on the router is 80% to 90%.
Raju
dennis916 Wed, 08/06/2008 - 22:44
Hi Guys,
I got the same problem with my SRST, I tried to reconfigured it but there was no luck... is there a possibility that this could be a bug or something? do we have any resolution on this? Hope there is someone who can assist.
Many Thanks,
Dennis
Steellllllllll0 Thu, 08/07/2008 - 00:08
Hi Guys,
Are you using mgcp/h323//please post your config as well as a sh hardware or sh inventory...
dennis916 Sun, 08/10/2008 - 16:01
Hi Steel,
For the same problem We are experiencing, below is the configuration we did on the router, also We are using H323 for this gateway:
System image file is "flash:c3825-spservicesk9-mz.124-9.T7.bin"
Cisco 3825 (revision 1.2) with 482304K/41984K bytes of memory.
Processor board ID FHK1221F2WP
2 Gigabit Ethernet interfaces
31 Serial interfaces
2 Serial(sync/async) interfaces
1 terminal line
2 Channelized E1/PRI ports
1 cisco Integrated Service Engine(s)
Cisco Unity Express 3.1.1 in slot 1
DRAM configuration is 64 bits wide with parity enabled.
479K bytes of NVRAM.
125440K bytes of ATA System CompactFlash (Read/Write)
VoiceGateway#sho run
Building configuration...
interface GigabitEthernet0/0
description *** TO 3750 Core ***
ip address 192.168.40.3 255.255.255.0
duplex auto
speed auto
media-type rj45
h323-gateway voip bind srcaddr 192.168.40.3
call-manager-fallback
secondary-dialtone 9
max-conferences 4 gain -6
transfer-system full-consult
timeouts interdigit 3
ip source-address 192.168.20.3 port 2000
max-ephones 120
max-dn 200
system message primary CCM Publisher is offline
keepalive 45
no huntstop
date-format dd-mm-yy
Hope there is a resolution... Many Thanks in advance
Chad Stachowicz Sun, 08/10/2008 - 22:06
  • Silver, 250 points or more
paste the entire router config? sure you don;t have direct inward dial on a bad dial peer? ;)
Chad
dennis916 Mon, 08/11/2008 - 16:06
Sorry Guys my Bad... Here is the entire configuration for your reference, I keep troubleshooting at the moment and keeps on going back to square one... still no luck or solution...
