NAC guest server in a Intranet iframe
Jun 18th, 2008
Does anybody have tips on how to integrate the NAC guest server sponsor login into a Intranet page.
Maybe even get the active directory credentials from the intranet page login?
One method could be a iframe, but again have anybody done this in a clever way?
Best regards,
Steffen Lindemann
htarra Wed, 06/25/2008 - 05:46
  • Bronze, 100 points or more
The same server cannot be used in Inband and OOB at the same time. In OOB, you have an auth vlan to which all users are initially moved to.In this auth vlan, the user traffic will hit the NAC Server. You can configure the ACLs on the Unauthenticated role such that guest access is provided in the unauth role itself. The guest users wont have to authenticate or go through posture. They will have guest access in the auth vlan. Hence a user connects to a switchport and will get moved to the auth vlan. In the auth vlan, the guest users will have guest access already. Other users can go ahead and authenticate and then get moved to an access vlan for intranet access.
