NAC guest server and pre-configured duration of accounts
There seems to be a bug in the way the NAC guest server handles the pre-configured duration of guest accounts.
I have followed the manual and I did:
- Configured 3 durations (24h, 48h and 1 week) under the templates/accounts/accounts durations.
- And set "maximun duration of account" under User Groups
As I understand I should now be able to select one of the three configured durations when I login as a sponsor.
However I only get the number which I specified under User Group.
The odd thing is that if I change the Maximum duration under User Group, I get this as the only choice (e.g. 14 days).
Have other experienced this?
Best regards,
Steffen Lindemann
owillins
Level 6
Level 6
You can use any one of the option ie number of days or number of hours.
For days;
Authentication > User Groups > Add Group | Edit Group includes two new settings for Number of days in the future the account can be created and Maximum duration of account (in days)
For hours:
User Interface > Templates > Add Template | Edit Template > Accounts > Account Duration
http://www.cisco.com/en/US/docs/security/nac/guestserver/release_notes/11/gsrn110.html
owillins
Level 6
Level 6
For days;
For hours:
I got it to work.
I am not sure what I did wrong, but I think confused the "template" with a user template and not what it actually is, a language template.
