Serious security issue with ACS 3.3 and RSA ACE Token Server
Hi all,
we have a seriuos security issue with an ACS 3.3 server on windows running in front of an RSA ACE/Token Server 6.0. We use this setup to authenticate VPN users coming in over ASAs and VPN-3000 concentrators.
After running some time the ACS stops authenticating users. But the authentication does not fail instead the ACS allows any user to connect succesfully. We traced the communication between the ACS and the RSA ACE and found that the ACS does not talk to the RSA server anymore, but nevertheless allows the users to connect. Whats even worse - the user can supply any token code - valid or not !
In summary the ACS allows any user to succesfully connect with in invalid token codes.
After stopping and restarting the services on the ACS anything works normally.
Any help is appreciated since this is a serious issue for us.
Kind regards
Markus
darpotter Thu, 06/19/2008 - 05:08
  • Silver, 250 points or more
Do you have token caching enabled in ACS?
Jagdeep Gambhir Thu, 06/19/2008 - 06:23
  • Red, 2250 points or more
Strange... what is the complete ver of acs and on which operating system & SP it is installed ?
~JG
Jagdeep Gambhir Fri, 06/20/2008 - 06:08
Markus,
ACS software's are not listed on CCO. You need to open a TAC case for getting it.
~JG
Do rate helpful posts
cisco24x7 Fri, 06/20/2008 - 07:32
I have the same exact issue as described
by Markus but my RSA SecurID is version 5.1.
I am using the same ACS version as Markus
on Windows 2000 with Service Pack 4. Stop/Start
Cisco ACS services did not resolve the issue.
To fix this, I have to reboot the Win2k box
every 48 hours.
I am thinking that it may be a bug in this
version of ACS.
