CallManager Trunck
Jun 19th, 2008
i have 3 Sites :
Site A [ CallManager Cluster A]
Site B [ CallManager Cluster B]
Site C [ CallManager Cluster C]
the connection betwen A and B already exist by trunk [ CCM-A & CCM-B].
Now i want to configuer a trunk betwen CCM-B and CCM-C, i want olny the iphones in site C call the iphones in the site B
how can configure that .?
thanks in advance
Hicham
Zin.Karzazi Thu, 06/19/2008 - 03:37
  • Silver, 250 points or more
First you need to set up a route pattern to your remote site. Let s say your DNs on site C are 7xxx and your remote site B is using 6xxx.
set up a route pattern 6xxx and select the trunk Route List in it.
1- Include the Partition of your Route pattern (6xxx) in the CSS of your phones.
2- Ensure that the route list on your RP is correct (ie Trunk Route List)
3- on your remote trunk-> Inbound call -> CSS
check if this css include the Partition of your phones.
You do this just for the C Site, the phones on the B Site will not be able to Call to C Site.
Zin Elabidine Karzazi
