ASA "crypto isakmp identity" command
Jun 19th, 2008
Hi all,
I have an ASA 5510 with several L2L VPNs configured.
One of the L2L VPN needs me to configure "crypto isakmp identity key-id xxyyzz" instead of "crypto isakmp identity address".
The problem is that this is a global command in the ASA and when I do this change the new tunnel starts working but one of the previous ones stops working...
Is there any way I can configure the ASA in order to support both of these configurations according to the L2L tunnel?
Thank you very much for your support.
Best regards,
John
Farrukh Haroon Thu, 06/19/2008 - 03:53
  • Red, 2250 points or more
This is supported on IOS using ISAKMP profiles, I don't think this can be done on the ASA/PIX. However it would be interesting to learn about a work-around.
Farrukh
