incorrect time in log file
Answered Question
Jun 19th, 2008
we have several cisco switches. we have NTP setup running on a msfc of a 6500. switches are set to get time from 6500. the show clock command on the switches show the correct time. But when something is put in the log file of the switch,the time is 4 hours ahead. Any ideas?? Thanks
Correct Answer by Kevin Dorrell about 8 years 9 months ago
It sounds like it is logging with UTC timestamps instead of the local timezone. Try:
service timestamps log datetime localtime show-timezone
Kevin Dorrell
Luxembourg
Overall Rating: 5 (5 ratings)
Correct Answer
Kevin Dorrell Thu, 06/19/2008 - 06:45
  • Green, 3000 points or more
Kevin Dorrell
Luxembourg
broow Thu, 06/19/2008 - 06:55
you da man,
thanks, that was it.
Richard Burts Fri, 06/20/2008 - 11:40
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
William
If that was it, then rating the post (with a 5) and using the check mark assignment would be a good way to indicate to people who read the forum that a solution had been provided.
Rick
