ASA 7.2(2) ssl vpn (full tunnel mode)
Jun 19th, 2008
After changing the default port 443 to e.g. 442 for the WebVPN access I see the following behaviour:
- clientless access mode is working as befor
- full tunnel client access mode gives the following error message:
"The SSL VPN to the remote peer was disrupted and could not automatically be re-established. A new connection requires re-authentication and must be started manually."
After changing the port nbr. back to 443, everything was working fine again. Beside changing the port number, ist there any thing else to consider?
Thank's for any reply,
Daniel
ASA Version 7.2(2)
hostname fwrexu01
domain-name xy.local
enable password x encrypted
names
interface Vlan1
description LAN
nameif inside
security-level 100
ip address 192.168.24.254 255.255.255.0
interface Vlan3
description Outside, WebServer
nameif outside
security-level 0
ip address 192.168.23.254 255.255.255.0
access-list outside_access_in extended permit tcp any host 192.168.24.20 eq https
access-list outside_access_in extended permit tcp any host 192.168.24.20 eq smtp
access-list outside_access_in extended permit icmp any any echo-reply
access-list inside_access_in extended permit ip any any
access-list inside_access_in extended permit icmp any any echo
access-list inside_nat_outbound extended permit ip 192.168.24.0 255.255.255.0 19
2.168.1.0 255.255.255.0
access-list backup_access_in extended permit icmp any any echo-reply
pager lines 24
logging enable
mtu inside 1500
mtu backup 1500
mtu outside 1500
ip local pool WebVPN 192.168.200.10-192.168.200.100 mask 255.255.255.0
arp timeout 14400
global (backup) 1 interface
nat (inside) 1 access-list inside_nat_outbound norandomseq
access-group inside_access_in in interface inside
access-group outside_access_in in interface outside
route outside 0.0.0.0 0.0.0.0 192.168.23.1 1 track 1
group-policy WebVPN-Policy internal
group-policy WebVPN-Policy attributes
dns-server value 192.168.24.20 195.186.1.111
vpn-tunnel-protocol webvpn
webvpn
functions url-entry file-access file-entry file-browsing
url-list value Servers
customization value Rexult-WebLogin
svc enable
svc keep-installer installed
svc rekey time 30
svc rekey method ssl
tunnel-group DefaultWEBVPNGroup general-attributes
address-pool WebVPN
authentication-server-group RADIUS LOCAL
default-group-policy WebVPN-Policy
tunnel-group DefaultWEBVPNGroup webvpn-attributes
customization Rexult-WebLogin
nbns-server 192.168.24.20 timeout 2 retry 2
no vpn-addr-assign aaa
no vpn-addr-assign dhcp
console timeout 0
management-access inside
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
service-policy global_policy global
ntp server 192.168.24.20 source inside
webvpn
port 442
enable outside
csd image disk0:/securedesktop-asa-3.1.1.45-k9.pkg
csd enable
svc image disk0:/sslclient-win-1.1.3.173.pkg 1
svc enable
title text Rexult WebVPN Service
logo none
url-list Servers "Outlook WebAccess" https://192.168.24.20/exchange 4
prompt hostname context
: end
druch Sun, 07/06/2008 - 01:24
Thank's for the link. But my problem is not the clientless SSL VPN mode. The SVC is not working afer changing the port. Does the scv client needs to be installed again after the port change?
