3845 T1 voip dial peer
Jun 19th, 2008
Scenario is, customer calls 18669149049 and the call hits the router with digits 8669149049 where t1 is terminated , i have created a dial peer with incoming called number as 8669149049 and session target as call manager and i have created an extension 8669149049 in CM to make the call land into the extension.
The prob is whenever customer calls the tollfree he gets a dialtone (as if waiting for digits to be entered) and the call disconnects.
I can see the router log that the call has landed onto one of my t1 channel and found that even my dial-peer is matched but the caller hears a dialtone and gets disconnected.
any suggestions..
dial-peer voice 101 voip
translation-profile incoming block
preference 1
session protocol sipv2
session target ipv4:10.10.10.51
incoming called-number 8669149049
dtmf-relay rtp-nte h245-signal h245-alphanumeric
codec g711ulaw
no vad
voice-port 0/0/0:23
bearer-cap Speech
interface Serial0/0/0:23
no ip address
encapsulation hdlc
isdn switch-type primary-ni
isdn incoming-voice voice
no cdp enable
controller T1 0/0/0
framing esf
linecode b8zs
pri-group timeslots 1-24
mattcalderon Thu, 06/19/2008 - 07:30
  • Silver, 250 points or more
Try this:
Add a pots dial peer
dial-peer voice 100 pots
direct-inward-dial
Then change your voip from incoming called number to a destination pattern.
rafi.imran Thu, 06/19/2008 - 08:08
Thanks matt.
It worked. But is it mandatory to bind an inbound t1 pots dial peer to a voip dial peer...
Is this the only way it works???
mattcalderon Thu, 06/19/2008 - 08:18
Exactly as explained above. You have two call legs involved here, a pots leg and a voip leg. You were receiving the second dial tone because the direct inward dial was not applied on a pots dial peer
rafi.imran Thu, 06/19/2008 - 11:35
I did not create a pots dial peer at all initially still i was i getting a dial tone....i had only the dial peer...hence i raised the question whether i need to create pots dial peer and bind it with the voip dial peer...
