CISCO2821-SRST/K9
Rafael Jimenez
Level 4
Level 4
is included the power supply PWR-2821-51-AC
in the CISCO2821-SRST/K9 Part Number?.
thanks
2 Accepted Solutions
hsitar007
Hello Rafael,
The Cisco 2821 chassis comes with the power supply included. Not sure if you would get the same part number mentioned above. Looks like that part would fit in for a 2821 and 2851.
Hope this helps
Ratish
CISCO2821-SRST/K9 comes with the Power Supply you mentioned by default. You just need to select the appropriate power cable.
-> Sushil
hsitar007
Hello Rafael,
Hope this helps
Ratish
-> Sushil
