DSP questions
Answered Question
Jun 19th, 2008
When defining enhanced conference resources on a 3825 Router . I defined 16 conferences. Does it refer to an actual conference with a certain amount of user streams, utilizing the same resource or does it reflect a user based conference stream? In which case 16 conferences would be 16 actual users per one or more conference.
Is there a limit on an amount of meet-me conferences a CCM 4.1.3 can support. What is the limit on participants per each meet-me conference. Please answer the same questions in regards to AD-HOC conferences.
Also, it is possible to chain multiple meet-me conferences? What about across clusters? For example 10 users in cluster A one of cluster A users conferences in a Meet-me session in Cluster B?
Last but not least.
For example. we have 2 or 3 routers will DSP's providing conference and transcoding resources. Is Callmanager capable assigning resources from all 3 routers for users within the same conference and transcoding session, or is there any kind of limitation or restriction on those abilities.
Correct Answer by Jaime Valencia about 8 years 8 months ago
several of this questions have been already answered throughly on previous posts.
a conference session means that you will allocate all the channels at once. usually 8 participants per session using g711 or 2 if using G71 / 729 due to the fact it also needs to XCODE.
You can refer to the SRND under the Media resources for more explanation.
a SW conference bridge can handle at most 128 streams.
under service parameters you define how many ad-hoc and how many users for meetme
based on that number 128/number of users, just do the math. the sum of both should not be more than 128 per SW CFB.
usually the limit is set to 48 users on SW for ad-hoc and 64 for meetme. be aware you will get all the resources once you ask for a conference, they're not dynamic
it's possible to join one meet-me with other one, though it's not the best thing to do.
you can do it inter-clusters, just as you can do it by having PSTN users join the meet-me.
the one that creates the meet-me determines which resources will be used
if you set the resources under the same MRG they will be used in a round-robin fashion to distribute the load. no issue on that, i've seen guys that have over 50 CFBs and XCODERS on the same cluster with no issues, just configure the right way the MRG and MRGLs
as i mentioned, read the SRND under media resources, very good reference on all this
javalenc
if this helps, please rate
Overall Rating: 5 (2 ratings)
Correct Answer
Jaime Valencia Thu, 06/19/2008 - 08:11
javalenc
Chris Deren Thu, 06/19/2008 - 08:17
the defined maximum sessions defines how many conference bridges will be available. With PVDM2 chipsets each conference can support up to 8 participants. Here is a good doc on this topic:
http://www.cisco.com/en/US/docs/ios/12_3/vvf_c/interop/intcnf2.html
There is really no limit on meetme in CM, the limit is your resources. The default number of aprticipants is 4 and can be increased to 8. Same applies to ad-hoc.
You can not chain meet me conferences, you can chain ad-hoc conference I belive in CM 6.1 or 7.0 (7.0 is not out yet, I dont recall which one introdeces the feature).
Once a conference bridge is established all calls joining it will join the same conference brdige hence the same DSP (PVDMs), so the answer is NO.
HTH,
Chris
