Ironport An error occurred while retreiving data !
Jun 19th, 2008
Hi all :
The Ironport C150 AsynOS 5.5 work properly but the incoming mail graph didn't display any data and tell me that " An error occured while retreiving data " .
So anyone can tell me why and how i fix this problem ?
:oops:
kluu_ironport Thu, 06/19/2008 - 18:09
We see this problem after an improper reboot. This problem is probably related with report database. You may need to contact Technical Support so that they can verify this and see how to proceed from there.
Hi all :
:oops:
wolfpack.ironport.com> diagnostic
Choose the operation you want to perform:
- RAID - Disk Verify Utility.
- NETWORK - Network Utilities.
- REPORTING - Reporting Utilities.
[]> reporting
The reporting system is currently enabled.
- DELETEDB - Reinitialize the reporting database.
- DISABLE - Disable the reporting system.
[]> deletedb
This command will delete all reporting data and cannot be aborted. In some instances it may take several minutes to complete. Please do not attempt a system restart until the command has returned. Are you sure you want to continue? [N]> y
