Fast Busy when sending calls over Intercluster Trunk to PSTN
Jun 19th, 2008
I have CCM6.1(2) setup in a lab w/ a Intercluster trunk connecting to our Production 4.2(3)environment. I can place calls back and forth between the two clusters over the ICT so the trunk is working, but I cannot place calls from the lab to PSTN via the ICT. I see the calls on the H323 gateway, but I get a fast busy on the phone. A debug on the H323 Gateway shows this:
Cause i = 0x80AC - Requested circuit/channel not available
Any ideas? Thanks.
Chris Deren Thu, 06/19/2008 - 12:28
You are sending 10 digits "2027115911" is this what you want? Is 10 digit dialing allowed in this area code? What happens when you send the call as 7 or 11 digits?
Chris
d-roush Thu, 06/19/2008 - 12:33
Yes. In the DC Area, you can send out 7, 10 & 11 Digits. I have dial-peers setup on the voice gateway for all 3. Sening out 7 digits gets the same result.
