877 browsing prob
Answered Question
Jun 19th, 2008
i hav setup this wireless router thru sdm and cd and ppp lights r stable but im unable to browse on the internet. its a pppoe connection wid 0/103...........i have entered everything correctly but i cant solve this prob........
Correct Answer by Paolo Bevilacqua about 8 years 8 months ago
please configure:
interface range FastEthernet0 - 3
switchport mode access
switchport portfast
interface Vlan1
no ip tcp adjust-mss 1452
interface Dialer1
ip mtu 1492
ppp ipcp default route
interface BVI1
no ip forward-protocol nd
Overall Rating: 5 (1 ratings)
mustafa_chapal Thu, 06/19/2008 - 09:29
my config is
Building configuration...
Current configuration : 6156 bytes
! Last configuration change at 22:11:54 Karachi Thu Jun 19 2008 by Mustafa
! NVRAM config last updated at 22:12:07 Karachi Thu Jun 19 2008 by Mustafa
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname yourname
boot-start-marker
boot-end-marker
logging buffered 51200
logging console critical
enable secret 5 XXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
clock timezone Karachi 5
crypto pki trustpoint TP-self-signed-2761353319
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2761353319
revocation-check none
rsakeypair TP-self-signed-2761353319
crypto pki certificate chain TP-self-signed-2761353319
certificate self-signed 01
3082024F 308201B8 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
31312F30 2D060355 04031326 494F532D
quit
dot11 ssid CHAPAL
authentication open
guest-mode
no ip source-route
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.10.10.1
ip dhcp pool sdm-pool1
import all
network 10.10.10.0 255.255.255.0
default-router 10.10.10.1
dns-server 203.99.163.240 203.99.163.243
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
no ip bootp server
ip domain name yourdomain.com
ip name-server 203.99.163.240
ip name-server 203.99.163.243
username Mustafa privilege 15 secret 5 XXXXXXXXXXXXXXXXXXXXXXXXX
archive
log config
hidekeys
ip tcp synwait-time 10
ip ssh time-out 60
ip ssh authentication-retries 2
bridge irb
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.2 point-to-point
pvc 0/103
pppoe-client dial-pool-number 1
interface FastEthernet0
switchport mode trunk
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Dot11Radio0
no ip address
ssid CHAPAL
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0
54.0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$FW_INSIDE$
no ip address
bridge-group 1
interface Dialer1
ip address negotiated
ip mtu 1452
ip nat outside
ip virtual-reassembly
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap pap callin
ppp chap hostname 0215862424
ppp chap password 7 XXXXXXXXXXX
ppp pap sent-username 0215862424 password 7 XXXXXXXXXXX
interface BVI1
description $ES_LAN$
ip address 10.10.10.1 255.255.255.0
ip nat inside
ip tcp adjust-mss 1412
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface Dialer1 overload
logging trap debugging
access-list 1 remark INSIDE_IF=BVI1
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 10.10.10.0 0.0.0.255
dialer-list 1 protocol ip permit
no cdp run
control-plane
bridge 1 protocol ieee
bridge 1 route ip
Correct Answer
Paolo Bevilacqua Thu, 06/19/2008 - 10:25
please configure:
switchport portfast
interface Vlan1
interface Dialer1
ip mtu 1492
interface BVI1
