Trunking issue
Jun 19th, 2008
Issue between two switches.
Switch1 is uplink switch (WS-C3524-XL),FastEthernet0/24 in vlan 1 by default, is connected to Switch2(WS-C2960-48TT-L) to Gi0/1.
When i put Gi0/1 in
interface GigabitEthernet0/1
switchport mode trunk
speed 100
end
it does not make any change , but when i put Switch1 port f0/24 into
switch port mode trunk i lost the connectivity.
i suspect issue in switch2 g0/1 port because when it is configured for trunk or in vlan1 i do not see any change.
vlan1 is management vlan .
pls suggest !!!
thotsaphon Thu, 06/19/2008 - 10:36
  • Gold, 750 points or more
rohit,
Can you post the errors you mentioned?
Are all interfaces up?
please post a "show int status o" command n both interfaces?
Hopes you are testing connections from the vlan1. If not, Have all switches been added the vlans?
Thot
rohitraizaday Thu, 06/19/2008 - 19:32
Both switch have same vlan database, issue is all the vlan are not communicating except vlan1.
thotsaphon Fri, 06/20/2008 - 04:01
Rohit,
I should use either "dot1q" or "ISL" on both switches. Seems you are using Vlan1 as a native vlan. So dot1q will let vlan1 go without tagging but ISL does. Let's check WS-C3524-XL.
please do "sh inter trunk" command.That will explore what is happening.
Thot
rohitraizaday Fri, 06/20/2008 - 05:19
Thanks for you help, but issue has been fixed.
uplink switch port was not supporting truck.
After changing port it start working.
