How To Upgrade ASA Software Without Losing Config?
Jun 19th, 2008
Hello All. We are using an ASA 5520 device. We want to install the latest software on the device, but we do not want to lose our current firewall configuration. How do we do this? Thanks.
Overall Rating: 5 (1 ratings)
Farrukh Haroon Thu, 06/19/2008 - 11:07
  • Red, 2250 points or more
The software is not lost during the upgrade. However its a best-practice to take a backup before you do so. Just check the release notes for that particular release before upgrading for any 'caveats'.
Farrukh
AnnaStephanie Thu, 06/19/2008 - 12:35
Thanks for the advice. I figured out how to make a copy of the files sucessfully. I was able to upgrade the asa image file without losing the current firewall config. Thanks.
AnnaStephanie Thu, 06/19/2008 - 13:08
Hi Michael, the ASA software files? Click Support-->Security-->Under Multi-function Security select Multi-function security appliances, in the last box, click on Cisco ASA 5500 Series Adaptive Security Appliances. Then click on the Download Software link. You then have to logon to the Cisco site to download the .bin files. I hope this helps.
