"ip nat inside source static network" with route-map
Jun 19th, 2008
How would you use "ip nat inside source static network" with an route-map? The specific situation is:
Inside LAN: 192.168.1.0/24
The inside LAN address should be NAT'd to 172.30.11.0/24 only if the traffic is going to 172.30.10.0/24.
I have tried the following with no luck:
ip access-list extended nat-acl
permit ip 192.168.1.0 0.0.0.255 172.30.10.0 0.0.0.255
route-map nat-map permit 10
match ip addres nat-acl
ip nat inside source static network 192.168.1.0 172.30.11.0 /24 route-map nat-map
However, if the route-map is not specified in the "ip nat inside source static network", the translation works for all traffic.
On the other side, I was able to set this up with "ip nat pool" and route-map.
ip nat inside source list nat-acl route-map nat-map pool nat-pool
ip nat pool nat-pool 172.30.11.0 172.30.11.255 netmask 255.255.255.0 type match-host
Any advice is appreciated!
Thanks!
Jon Marshall Thu, 06/19/2008 - 13:00
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Zhen
The way you have set it up is the correct way although if you are not matching on something other than source & destination IP addresses you could just as easily have done
ip nat inside source list nat-acl pool nat-pool
ie. you only need a route-map if you want to match on other things such as next-hop ip address/output interface etc.
You would not use the static statement -
because you are dynamically Natting source IP addresses not statically mapping them.
Hope this makes sense.
Jon
zhenxu_zj Thu, 06/19/2008 - 19:11
Indeed, I do need static one-to-one mapping so that outside host (from 172.30.10.0/24) can access the internal host (182.168.1.0/24) via the nat'd outside address (172.30.11.0/24).
Jon Marshall Fri, 06/20/2008 - 07:17
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Zhen
Sorry i didn't explain it properly. Even though you want a one to one mapping you are still dynamically allocating them as needed ie. until traffic passes through the router the NAT translation is not there and after a period of inactivity the translation is removed.
Jon
