E1 card
Jun 19th, 2008
i have an NM-2CE1T1-PRI CARD.I would like to know if there is an equipment(modem or card) which could enable the router to receive E1 VOICE traffic?.I must say that an rj11 connector is coming from the telecom provider.
Paolo Bevilacqua Thu, 06/19/2008 - 12:33
  • Hall of Fame,
    Founding Member
Excuse me, you have been told already by more than one person that the card you reference doesn't support voice, and ask the same again ?
If you had not noted, that is a professional forum with multiple active contributors. I have never seen a case where wrong information was forwarded without a further correction by same or other person.
The same applies to your case, you have been given correct information, I'm sorry if that brings the bad news that you have to buy a new card and PVDM2 modules, but that is the way it is.
You have also been told that E1 comes in form of an RJ45 connector with 8 pins, not RJ11 with 6, so you should double-check what you have from the telecom provider.
