3560 8 routed interfaces
Jun 19th, 2008
When a C3560 SDM is set to "desktop routing"; the 'show SDM prefer' output indicates that the given features are supported for 8 routed interfaces. What is the impact to the switch if more than 8 interfaces are configured for routing? Are the listed feature resources sub-divided amongst the interfaces? Or worse, does the 3560 fall into software switching for all / some traffic (inducing high CPU load)?
Thanks in advance!
aghaznavi Wed, 06/25/2008 - 06:04
There is no defined limit to the number of SVIs and routed ports that can be configured in a switch. However, the interrelationship between the number of SVIs and routed ports and the number of other features being configured might have an impact on CPU usage because of hardware limitations.
http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.2_25_se/configuration/guide/swint.html#wp1414356
