No MoH on UCM 6.1(2)
Answered Question
Jun 19th, 2008
We moved from Callmanager 4.2(3) to UCM 6.1(2). DMA seemed to migrate all the data, but it appears Music on Hold is not working. I'm guessing this should be simple, but I can't seem to find the source of the problem. Music source exists, MoH server is running, and Media streaming service is running. Any ideas?
Thanks in advance.
Correct Answer by Chris Deren about 8 years 8 months ago
Did you have custom MOH files? These do not get migrated via DMA, make sure you re-upload these.
Chris
Overall Rating: 5 (1 ratings)
Correct Answer
Chris Deren Thu, 06/19/2008 - 12:53
Chris
thisisshanky Thu, 06/19/2008 - 13:01
Also make sure you upload the files individually to all the MOH servers in the clusters...These files are not sync'd
mcarter@thdg.com Wed, 06/25/2008 - 06:55
This post was exactly what i was looking for.
I have been searching online for a while about this issue. Thanks guys!!!!
Chris Deren Wed, 06/25/2008 - 07:04
Cool, make sure you rate the post so it's easier for others to find in the future.
Chris
