Accessing LAN while VPNing
Jun 19th, 2008
Yes I've gone through this article:
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a0080702992.shtml
I can't seem to get it working. I'm getting NO TRANSLATION GROUP FOUND FOR TCP... when I try testing using a UNC path to a machine on the LAN. I'm new to playing around with ASA so bare with me. I know it has something to do with access-list and NAT.
ciscoasa# sh run
: Saved
ASA Version 8.0(2)
hostname ciscoasa
enable password xxx
names
interface Ethernet0/0
nameif Outside
security-level 0
ip address x.x.x.x 255.255.255.224
interface Ethernet0/1
nameif inside
security-level 100
ip address 172.17.193.1 255.255.255.0
interface Ethernet0/2
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
nameif management
security-level 100
management-only
passwd xxx
ftp mode passive
clock timezone MST -7
clock summer-time MDT recurring
pager lines 24
logging enable
logging asdm informational
mtu Outside 1500
mtu inside 1500
mtu management 1500
ip local pool Addr_Pool_1 192.168.10.101-192.168.10.254 mask 255.255.255.0
no failover
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-602.bin
no asdm history enable
arp timeout 14400
global (Outside) 1 interface
nat (inside) 1 172.17.193.0 255.255.255.0
route Outside 0.0.0.0 0.0.0.0 x.x.x.x 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 192.168.1.0 255.255.255.0 management
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
no crypto isakmp nat-traversal
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 172.17.193.101-172.17.193.254 inside
dhcpd dns x.x.x.x x.x.x.x interface inside
dhcpd enable inside
dhcpd address 192.168.1.2-192.168.1.254 management
dhcpd enable management
threat-detection basic-threat
threat-detection statistics access-list
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
webvpn
enable Outside
svc image disk0:/anyconnect-win-2.2.0133-k9.pkg 1
svc enable
group-policy DfltGrpPolicy attributes
vpn-tunnel-protocol IPSec l2tp-ipsec svc webvpn
address-pools value Addr_Pool_1
username user1 password tJsDL6po9m1UFs.h encrypted
prompt hostname context
Cryptochecksum:xxx
: end
ciscoasa#
acomiskey Fri, 06/20/2008 - 06:01
  • Green, 3000 points or more
You are missing nat exemption.
access-list inside_nat0_outbound extended permit ip any 192.168.10.0 255.255.255.0
nat (inside) 0 access-list inside_nat0_outbound
