ACS 3.3 PEAP authentication problem
We're running ACS 3.3 on a Windows 2003 server. We're using this server for Radius and integrating a Windows database.
Our wireless clients use PEAP to authenticate.
Suddenly none of our wireless clients can authenticate throughout our enterprise, which is turning out to be quite a serious problem.
Our configuration hasn't changed. I'm wondering if something happened to our certificate. We're using a self signed certificate that we generated via ACS.
Can I simply issue a new cert via ACS and see what happens?
I'm really in a bind right now.
Overall Rating: 4.8 (5 ratings)
Jagdeep Gambhir Fri, 06/20/2008 - 06:32
  • Red, 2250 points or more
Self sign certs are only valid of one year. Since all wireless users cant connect, I believe that ACS cert has expired.
Please go ahead and install new SSCert.
~JG
Do rate helpful posts
Jagdeep Gambhir Fri, 06/20/2008 - 08:42
Yes, that is all we need to do. It will not effect any other settings.
~JG
Hello JG,
You are correct, thanks. Just paranoid, I guess.
In the ACS System Configuration to generate a new self signed cert, I want to make sure I don't need to change the any of the fields that are already entered. It looks like I just need to enter the private key password, and then check the box to "Install generated Certificate", and submit.
John
Jagdeep Gambhir Fri, 06/20/2008 - 14:11
John,
Please check your group mapping. It may be possible that user is getting mapped to disabled group.
If that is not the issue then we need to see auth.log , that will tell us what is the reason for failure.
Increase the loggin level to full and recreate the issue and see auth.log
~JG
Jagdeep Gambhir Mon, 06/23/2008 - 05:12
John,
I hope installing acs on another server, fixed it.
All the best !
~JG
